Can I Change the Value of the Digital Output Voltage in myRIO-1900?
Updated Jun 11, 2019
  • myRIO-1900
I saw that the Digital Input/Output (DIO) pins of the myRIO-1900 have a tolerance of 5V, so can I change the value of the Digital Output to be the value I want in that range?
The myRIO-1900 Digital Output cannot be manually or programmatically changed, it's configured to generate only a value of 3.3V.
The myRIO-1900 User Guide and Specifications  shows the range of values for the DIO pins of the device.
