NI Vision Builder for Automated Inspection Run-Time Restricted and Available Features
Updated Aug 19, 2026
  • Vision Builder for Automated Inspection
I am using NI Vision Builder for Automated Inspection (VBAI) Run-Time to deploy inspections. Some editing features that are available in the Development version appear unavailable. I would like to know which features can be used with a Run-Time license, and which features require a development license.
The VBAI Run-Time license is intended for executing and deploying existing inspections. It provides limited editing capabilities compared to a development license.
Available Features
  • Open inspections in either Inspection or Configuration interfaces.
  • Run inspections in both interfaces.
  • Edit controls in steps already included in an inspection.
  • Save inspections using Save and Save As.
  • Edit transitions between states.
Features Not Available in Run-Time
The Run-Time license does not allow modification of the inspection structure. The following features require a development license:
  • Add new steps, states, or transitions.
  • Delete existing steps, states, or transitions.
  • Disable existing steps.
  • Create new inspections.
VBAI Run-Time uses the same installer as the Development version. The enabled functionality depends on the activated license.  If an evaluation license is also present, VBAI may appear to have Development functionality until the evaluation license expires. To retain only Run-Time functionality:
  1. Navigate to: C:\ProgramData\National Instruments\License Manager\Licenses
  2. Remove license files beginning with "VisionBuilderAI..."
  3. Keep only license files beginning with "VisionBuilderAI_RT_PKG..."
  4. Restart VBAI and verify the activated license in NI License Manager.
Vision Builder AI Run-Time and Development versions use the same software installation. Upgrading from Run-Time to Development does not require reinstalling the software. To enable Development features:
  1. Purchase a Vision Builder AI Development license.
  2. Activate the Development serial number in NI License Manager.
  3. Restart Vision Builder AI.
After activation, Development functionality becomes available without additional installation.
