Este conteúdo não está disponível em seu idioma preferido.
O conteúdo é exibido em outro idioma disponível. Seu navegador pode incluir recursos que podem ajudar a traduzir o texto.
VI_ERROR_RSRC_NFOUND Unable to Create a VISA TCP/IP Resource for 3rd Party Instrument
Updated Apr 5, 2023
  • NI-VISA
I am using a a 3rd party instrument (for example a oscilliscope) and trying to create a VISA TCP/IP Resource. When I validate the resource, I get the following error:
Unable to open session to "TCPIP0::123::123::123.123.123::inst0::INSTR"
Return status code: 0xBFFF0011
Status name: VI_ERROR_RSRC_NFOUND
Insufficient location information or the device or resource is not present in the system.
I have checked the connection of the instrument and verified that it is connected correctly. Why am I unable to create a VISA TCP/IP Resource?
This issue occurs when the VXI-11 server for the 3rd party instrument is stopped. To start the VXI-11 server on the device, you will need to use the manufactures software to configure or restart it.
Once you start the VXI-11 server, you should be able to create a TCP/IP Resource and connect to the scope without any problems.
For more information about how to start the VXI-11 server, reference the Related Links section or contact the manufacturer of the instrument.
