RMX-10060 Topology or Compatibility with PXI Systems
Updated Jun 1, 2019
  • RMX-10060
I have found the RMX-10060 Emergency Power Switch and I would like to know if it is compatible with my PXI system. Does this product need any additional accessories or modules in order to be used with a PXI system? What is the recommended use of this device?
There's not a supported direct interface between the RMX-10060 and a PXI chassis. It is intended to be connected through one of the ATE Core Configuration  power distribution units.
