The Advanced Analog Measurement Option is allowed to use internal scope in order to measure Field Strength, LMA(Load Modulation Amplitude), PCD WaveForm.
If user want to measure LMA without Advanced Analog Measurement Option,
Follow the following steps to measure it:
1. Make simple transaction script by MPManager3
2. Adjust parameter value as your DUT
- RF Field applied level
- Select RX Channel – Analog IN
- Enable/Disable Spy command as you want
- CLTO 1 3 0 : TRIG1 port set as Logic”0” when TX OUT
3.Hardware Configuration
- External DSO(Digital Oscilloscope)
- MP500TCL3(or PT1)
- PICC-PCD Simulation ANT
- SMA T-Bridge, CONNECTORs
- ANALOG IN(MP500) à SMA T-Bridge à CH A(DSO) : Using DSO Probe
- ANALOG IN(MP500) à SMA T-Bridge à ANALOG IN(PICC-PCD Simulation ANT)
- TX/RX(MP500) à TX/RX(PICC-PCD Simulation ANT)
- AUX1(MP500) à HDMI CABLE à TCL3 HDMI(PICC-PCD Simulation ANT)
- TRIG1(MP500) à CH B or CH C (DSO)
- Set Trigger Condition of DSO (CH C)
- Trigger Run : Auto or Single
- RUN Test Script by MPManager3
- Capture the proper area with DSO
- Vertical Scale: Adjust (e.g. 200mV) , Time division: 1ms/div
