How Can I Know Which VIs in My Project Are Depreciated?
Updated May 31, 2019
I have a big application that I am migrating from old LabVIEW version to a later one. Is there a tool where I can know which parts of the code are depreciated so that I can modify it?
You can use this Depreciated Functionality Library to test which parts of your code are depreciated. You can also Mass Compile your code.
