Why is LabWindows™/CVI™ not Showing the Value of Variables When I Hover Over Them?
Updated Jul 5, 2019
  • LabWindows/CVI
When running and debugging an application in LabWIndows/CVI I used the values of variables when I hovered my mouse over them, but now the values are not showing, why is this happening?
To have the data tooltips appear when hovering over a variable it is necessary to enable the option, which is found in Options->Environment, where the Enable data tooltips option has to be enabled.
