What Version of the LabVIEW DSC Module Can I Use With My Version of LabVIEW?
Updated Sep 5, 2025
I'm considering installing the LabVIEW Datalogging and Supervisory Control Module on my system, and I'd like to make sure it's compatible.
What version of LabVIEW do I need to install to work with the DSC Module?
Like most of the modules for LabVIEW, you'll need to make sure that the version of the module matches your LabVIEW version. For example, if you're running LabVIEW 2023Q1, you'll need the 2023Q1 version of the DSC Module.
As of the LabVIEW DSC Module 2019, there is compatibility for Base, Full, and Professional versions of LabVIEW.
For more specific compatibility information, please check the DSC Modules' readme files.
