Customizing TestStand Report Options Dialog Box
Updated May 31, 2019
  • TestStand
I want to configure options in the TestStand Development Environment for the dialogue box found in Configure»Report Options. What sequence file or callback should I use?
To customize the Report Options Dialog box in TestStand, use the Model Plug-in NI_ReportGenerator.seq. This can be found at the file path C:\Program Files (x86)\National Instruments\TestStand 201x\Components\Models\ModelPlugins. Within that sequence file, you'll want to look at the ReportOptions model callback in particular. The subsequence Model Plugin - Begin calls the ReportOptions model callback to modify the report options from a client sequence file.
