I am measuring the pulse width of a digital pulse using my USB-type DAQ device. If I measure one pulse signal, the measurement has no problem. However, if I try to measure two pulse signals at the same time using two counters in the DAQ, the measurement values are incorrect as described below. How can I fix this?
correctly measured values incorrectly measured values
