You can use Ring indicators to display text on your GUI.
A Ring takes a numeric value, and displays the string accosted with that numeric value.
To use a Ring to display text, follow these steps:
1. Open the UI Manager you wish edit
2. Click on the
Pull Down section and select a
Ring. If the
3. Place the Ring on the UI Manager and make sure you can see the item properties on the right hand side of the screen
4. Scroll to the bottom of the properties and change the
Behaviour to
indicator5. Map the Ring to a numeric channel by clicking the mapping button
6. Untick
Populate with channel data so you can manually add the strings to output depending on the numeric.
7. If you want to add your own numeric values that map to strings, rather than the default equal to order, untick
Value equal to order8.. You can now click the + button to add strings and numeric values
