This article shows you how to download and register MPManager software.
Note: Please make sure that you are running MPManager as administrator. You will be given a Request license code which will be needed to activate your license and complete the registration.
After having applied the registration code provided, MPManager will be registered on your computer. Note that if you update MPManager with a newer version, you do not have to register MPManager again.
A valid service agreement may be required, and support options vary by country.
