Error -1074384783 Trying to Disconnect Can Controller Chip from the Connector with NI 9860
Updated May 26, 2019
  • NI-9860
  • NI-XNET 18.5
I am trying to disconnect the CAN controller chip from the connector using the property node Intf.CAN.TcvrType with Disc value
but the following error pop-up
Error -1074384783 occurred at Property Node (arg 1) in CAN Loopback Test.vi
Property : Intf.CAN.TcvrType
Why?
That property disconnects the CAN controller chip (transceiver) from the connector.
It is not possible to use it with NI 9860 because the CAN controller chip is in the cable and not in the module.
