Memmert Driver for LabVIEW Leads to Error DAbort 0xF50EFD7B
Updated May 21, 2019
Other
  • ATMORemote LabVIEW driver
I am using a third-party device from Memmert GmbH and downloaded the ATMORemote driver for the LabVIEW versions 2011 - 2013. While using the driver I am encountering the error message DAbort 0xF50EFD7B in MemoryManager.cpp:
In case you face the above mentioned error message, please try the successor version of the ATMORemote driver for the LabVIEW versions 2014 - 2017. You can find this specific ATMORemote driver on the Memmert website: ATMORemote LabVIEW 2014-2017
The ATMORemote driver for the LabVIEW versions 2011 - 2013 tries to call a specific .NET DLL and this can sometimes lead to incompatibilities. The driver for the LabVIEW versions 2014 - 2017 uses HTTP and does not need the specific DLL.
