Error -200452 Occurs When a 433x Device Uses Hardware Timed Single Point
Updated Jun 28, 2019
I have a PXIe system loaded with 433x devices for my application, and I am planning on using these cards in a  VeriStand project to interact with other pieces of my full system. However, I am running with error -200452 when I try to deploy my System Definition File. Why is this happening and how can I avoid it?
This is a known issue when you work with 433x devices using hardware timed single point acquistion. If a 433x device is set as the master or if there is only a 433x device in a system definition, using hardware timed single point will cause error -200452 to occur during deployment.
To avoid this issue, use at least one other device in your System Definition File to control the time for your tests.
