We generally recommend that you use the newest version of drivers compatible with your version of the
LabVIEW or
LabWindows/CVI development environment. More information about development environment compatibility can be found in the readme file for each version of the drivers.
Note: The readme is available on the driver's download page, highlighted in blue in the image below.
If you're also planning to do image processing in LabVIEW or LabWindows/CVI, Vision Development Module might be a good fit for your project.
We offer a trial version of this software that you can use to evaluate whether it fits your needs.
