NI-SWITCH Soft Front Panel Does Not Support RT Device
Updated Jul 2, 2019
  • PXIe-2727
  • PXI-8840
I have a programmable resistor module, and I want to use NI-SWITCH Soft Front Panel to configure it. When I open the Soft Front Panel I get the following error:
Error
You have selected an RT device.
The NI-SWITCH Soft Front Panel does not support remote RT device control.
NI-SWITCH Soft Front Panel does not support switch devices used with LabVIEW Real-Time. To get similar functionality, you can use the Soft Front Panel example VI.
