PPLs compiled in LabVIEW 2016 or earlier cannot be opened using other versions of LabVIEW. For example, if you try to use LabVIEW 2016 to open a PPL that was compiled in LabVIEW 2011, you will get the following error message:
LabVIEW: (Hex 0x623) You cannot open a packed library saved in a version earlier than the current version of LabVIEW.
Since LabVIEW 2017, you can compile a packed project library to be also used with newer versions of LabVIEW.
- Open the Packed Library build specification properties.
- Select Advanced.
- Enable Allow future versions of LabVIEW to load this packed library. (This option is enabled by default).
- Build the Packed Project Library.
