Error -1074395628 at IMAQ Learn Multiple Geometric Patterns
Updated Jun 11, 2019
  • Vision Development Module
When trying to use the IMAQ Learn Multiple Geometric Patterns VI, I get the following error message. How can I fix this?
Ensure you are using the IMAQ Learn Geometric Pattern to create your template image.
The IMAQ Learn Multiple Geometric Patterns and IMAQ Learn Geometric Pattern are part of the Geometric Matching - Feature Based VIs. You'll have to use the Feature Based version of the Geometric Matching VIs together to ensure they work properly without error.
