How can I Enable Scroll Bar in VI Properties
Updated May 16, 2019
I disabled scroll bars but I cannot enable scroll bars. I cannot enable Show vertical/horizontal scroll bar in Customize Window Appearance window. How can I enable?
First, if you don't know how to enable/disable scroll bars, please refer to the related links.
Why Show vertical/horizontal scroll bar categories are disabled is you use Horizontal/Vertical Splitter Bar on the Front panel. As you can see the exceptional sentence, you can apply only to single pane panel.
So if you want to enable scroll bars, you should try on the front pane. Please see the pictures below.
As you can see, you should mouse cursor on the Splitter Bar and right click. Then, you can see the Upper/Lower/Right/Left pane options.
If you remove the Splitter Bar, you can enable scroll bars in the Customize Window Appearance window.
