Este contenido no está disponible en su idioma de su preferencia.
El contenido se mostrará en otro idioma disponible. Su navegador puede proporcionar una funcionalidad para ayudarle a traducir el texto.
How Do I Print My Front Panel to PDF without Lossy Resolution?
Updated Nov 22, 2022
Whenever I print my Front Panel containing an image or logo to a virtual PDF printer, the image has a low resolution and appears pixelated.  How can I print to a PDF with good picture quality?
To avoid this loss in resolution, first print the Front Panel to an HTML file and choose a PNG format for the image. Next, open up the generated HTML or PNG file and proceed to print the file to the appropriate printer, whether it is a virtual PDF creator or a physical printer.
Please refer to the related link below for a detailed explanation of how to print the Front Panel to an HTML or image file.
