Solution 1If you want to choose a signal in DIAdem DAC with a NI-DAQmx driver input, you have to create it in NI Measurement & Automation Explorer (MAX) first.
Carry out the following steps:
- Open NI Measurement & Automation Explorer (MAX)
- Right-click NI DAQmx Global Virtual Channels under My System >> Data Neighborhood
- Select the option Create New NI-DAQmx Channel
- Configure the channel according to your requirements
Open the
MAX Signal List window again (close and reopen if it is opened). You should be able to see the channel you created listed in the
Available Signals (NI-DAQmx) section.
Solution 2Another possible cause could be issues with corrupt drivers or the order in which the programs were installed. A solution could be to reinstall all relevant software's and drivers. First
uninstall the software's listed below. Then make sure to install the software in the following order:
- Install DIAdem
- Install any patches
- Install Toolkits or Modules
- Install relevant Drivers, such as NI-DAQmx
