How to Calculate Accuracy of Resistance Measurement with SMU Board
Updated May 12, 2019
  • PXIe-4137
  • PXIe-4139
  • LabVIEW 2018
  • NI-DCPower 19.0
I need to do a local sense resistance measurement with a SMU board like PXIe-4139 or PXIe-4137. I need to calculate the accuracy of the measurement.
How can I do it?
Accuracy is related to Coefficient of variation (CV). It is measure of dispersion of a probability distribution or frequency distribution.
It is often expressed as a percentage, and is defined as the ratio of the standard deviation \ \sigma to the mean \ \mu
It is very easy to calculate using the Standard Deviation and Variance.vi after the record of different samples, as it is possible to see from the snippet below
According to ISO 5725-1 Accuracy consists of trueness (proximity of measurement results to the true value) and precision (repeatability or reproducibility of the measurement).
File:Accuracy (trueness and precision).svg
