Execution of External Command Error When Installing Software on cRIO
Updated Sep 24, 2019
  • CompactRIO Chassis
  • CompactRIO Controller
When I attempt to install the software on to my cRIO, the installation fails and I get the following error:
Measurement & Automation Explorer (error window):
NI-cRIO-90xx-"Name of cRIO" - (cRIO IP address): Execution of external command, script or application failed.
This issue can be solved by implementing the following steps:
  1. Power cycle the cRIO.
  2. Verify that any firewall has been deactivated or confirm that this firewall will not block any National Instruments Software installations.
    • Please speak to your Companies IT department if you are unsure.
  3. Deactivate any Antivirus software that will block any National Instruments Software installations.
  4. Connect the cRIO to the Host PC using a different connection port (i.e. An alternative Ethernet or USB port).
  5. Format the cRIO with the new connection type.
  6. Install all of the relevant cRIO software
If any of the installed software, toolkits or drivers are corrupt, broken, or not working as expected Force reinstall the software, toolkits or drivers
If the issue still persists. Please contact NI Support.
