My PXIe-8240 Can't Reach Its Maximum Data Rate
Updated Oct 29, 2019
  • PXIe-8240
  • PXIe-1075
I have brought a PXIe-8240 to transfer data at 40 Gb/s with an Ethernet port.
When I plug the module in my chassis (a PXIe-1075), the data rate is less than 4 Gb/s.
Why can't my PXIe-8240 reach the specification?
The issue comes from your chassis, in its datasheet, there is a part on High Performance for Instrumentation Requirements:
This part precises that the transfer rate will be at 1 GB/s maximum. That makes a maximum of 8 Gb/s.
So in this case, the chassis limits the transfer rate of the PXIe-8240.
