Mac OS X에서 NI-DAQmx Base를 삭제하는 방법
업데이트 됨 Apr 21, 2021
환경
드라이버
  • NI-DAQmx Base
운영 체제
  • Mac OS X
  • Mac OS X에서 NI-DAQmx Base를 제거하는 방법을 모르겠습니다.
  • 응용 프로그램 아이콘을 휴지통으로 버렸지만, 여전히 관련 파일이 존재합니다.
Mac OS X 용 NI-DAQmx Base는 여러 구성 요소 (NI-VISA 및 LabVIEW 2015/2016/2017 런타임 엔진)를 설치합니다. Mac OS X 용 NI-DAQmx Base를 제거하려면 다음 폴더와 파일을 시스템에서 삭제해야 합니다.
NI-DAQmx Base Common
/ Applications / National Instruments / NI-DAQmx Base
/Library/Frameworks/lib67xx.framework
/Library/Frameworks/libDIO96.framework
/Library/Frameworks/libESeries.framework
/Library/Frameworks/libmiteDma.framework
/Library/Frameworks/libmxBaseSessionTable.framework
/Library/Frameworks/libMSeries.framework
/Library/Frameworks/libSSeries.framework
/Library/Frameworks/libUSB-92xx.framework
/ Library / Application Support / National Instruments / NI-DAQmx Base
/ Library / Application Support / National Instruments / nipal / inf / nimxbase.inf
NI-DAQmx Base LabVIEW 2012/2013/2014/2015/2016/2017 VI
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/vi.lib/_DAQmxBase
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/vi.lib/_dmxb
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/examples/daqmxbase
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/project/daqmxbaseconfig.llb
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/project/daqmxbaseconfig.vi
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/help/lvdaqmxbase*
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/help/html/lvdaqmxbase*
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/menus/Categories/Measurement/daqmxbase.mnu
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/menus/Categories/Measurement/_daqmxbase
NI-DAQmx Base C Interface
/Library/Frameworks/nidaqmxbase.framework
/Library/Frameworks/nidaqmxbaselv.framework
/Applications/National Instruments/NI-DAQmx Base/examples
/Applications/National Instruments/NI-DAQmx Base/includes
/Applications/National Instruments/NI-DAQmx Base/documentation/docsource/daqmxbasecfunc*
/Applications/National Instruments/NI-DAQmx Base/documentation/DAQmxBase C Function Ref Help.html
NI-DAQmx Base USB Support
/ Applications / National Instruments / NI-DAQmx Base / bin
/System/Library/Extensions/niusb9162k.kext
추가 정보
위에서 언급된 파일을 보려면 Mac OS X 컴퓨터에서 / Applications / National Instruments / NI-DAQmx Base / Uninstall.txt를 참조하십시오.
참고 : NI-DAQmx Base는 macOS 10.14 및 이전 버전과 호환 됩니다. 이 드라이버에 대해 지원되는 모든 버전에 대한 macOS 호환성을 확인하십시오. 자세한 내용은 DAQmx Base Driver 의 단종 발표 문서를 참조하십시오.
