How Do I Uninstall NI-DAQmx Base from Mac OS X
Updated Dec 23, 2023
  • NI-DAQmx Base
  • Mac OS X
  • I don't know how to uninstall NI-DAQmx Base on Mac OS X.
  • I dragged the application's icon to the Trash and emptied it, but I still have other files scattered around my Mac.
NI-DAQmx Base for Mac OS X installs a number of files, optional components and two support packages: NI-VISA and LabVIEW 2015/2016/2017 Runtime Engine. In order to uninstall NI-DAQmx Base for Mac OS X, you have to move the following files and folders from your system to the Trash and empty it afterwards:
NI-DAQmx Base Common
/Applications/National Instruments/NI-DAQmx Base
/Library/Frameworks/lib67xx.framework
/Library/Frameworks/libDIO96.framework
/Library/Frameworks/libESeries.framework
/Library/Frameworks/libmiteDma.framework
/Library/Frameworks/libmxBaseSessionTable.framework
/Library/Frameworks/libMSeries.framework
/Library/Frameworks/libSSeries.framework
/Library/Frameworks/libUSB-92xx.framework
/Library/Application Support/National Instruments/NI-DAQmx Base
/Library/Application Support/National Instruments/nipal/inf/nimxbase.inf
NI-DAQmx Base LabVIEW 2012/2013/2014/2015/2016/2017 VIs
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/vi.lib/_DAQmxBase
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/vi.lib/_dmxb
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/examples/daqmxbase
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/project/daqmxbaseconfig.llb
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/project/daqmxbaseconfig.vi
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/help/lvdaqmxbase*
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/help/html/lvdaqmxbase*
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/menus/Categories/Measurement/daqmxbase.mnu
/Applications/National Instruments/LabVIEW <2012 | 2013 | 2014 | 2014 64-bit | 2015 | 2015 64-bit | 2016 | 2016 64-bit | 2017 | 2017 64-bit>/menus/Categories/Measurement/_daqmxbase
NI-DAQmx Base C Interface
/Library/Frameworks/nidaqmxbase.framework
/Library/Frameworks/nidaqmxbaselv.framework
/Applications/National Instruments/NI-DAQmx Base/examples
/Applications/National Instruments/NI-DAQmx Base/includes
/Applications/National Instruments/NI-DAQmx Base/documentation/docsource/daqmxbasecfunc*
/Applications/National Instruments/NI-DAQmx Base/documentation/DAQmxBase C Function Ref Help.html
NI-DAQmx Base USB Support
/Applications/National Instruments/NI-DAQmx Base/bin
/System/Library/Extensions/niusb9162k.kext
Support Packages
Please refer to /Applications/National Instruments/NI-DAQmx Base/Uninstall.txt  on your Mac OS X computer to have visibility of the files mentioned above.
Note: NI-DAQmx Base is compatible with macOS 10.14 and earlier versions – check macOS compatibility for all supported versions for this driver. For more information, please read the End-of-Life Announcement for DAQmx Base Driver .
