이 내용은 고객님의 설정 언어로 확인할 수 없습니다
Fixing VISA Overrun Error (Error -1073807252 (Hex 0xBFFF006C))
Updated Apr 2, 2025
  • NI-VISA
  • NI-Serial
I am using serial communication with VISA to send and receive data from hardware in LabVIEW.  I keep getting the following error:
VISA: (Hex 0xBFFF006C) An overrun error occurred during transfer. A character was not read from the hardware before the next character arrived.
This error occurs when data is available for a subsequent read before the current read has finished executing.  To fix this, we need to read data from the device faster by doing one or more of the following.
  • Increase the baud rate between the computer and the external device
  • Reduce the amount of data being passed through the bus
  • Change the read and write architecture of the LabVIEW VI to Producer/Consumer Architecture
  • Use the VISA Flush I/O Buffer VI by setting the correct buffer type from the VI's options.
If this error is intermittent, you should double-check that your other Instrument Control Properties (such as Parity and Stop Bits) are set correctly for your device.
