Incompatible Software Versions: the error could occur if the version of PXI Platform Services on your host machine and the combination of the version of PXI Platform services and NI VISA on your RT target are not compatible.
Chassis EEPROM: The impact of using a chassis in this state is that MAX will report this error and you will not be able to manually reserve PXI Trigger lines through MAX as described in
Routing PXI Trigger Lines Across the Buses of Multisegment PXI Chassis. All other functionality of the chassis will not be affected by this issue.
- To see if your chassis is affected by this issue you can use the System Configuration API with LabVIEW to read the serial number of the chassis. If a '?' appears in the serial number then this issue is affecting your chassis.
- Alternatively you may continue using a chassis in this state if you do not require the ability to manually reserve PXI Trigger lines.
Note: There is a small chance that NI will report a chassis in this state as No Trouble Found during repair however the serial number will be corrected in the chassis EEPROM during the testing process resolving the issue.
