Detect Array Element Value Change in LabVIEW
Updated Feb 10, 2026
I would like to be informed which element in an array has its value changed. How to get the desired element index?
There is no built-in LabVIEW function to achieve described functionality out of the box. However, you can get the changed value index from the array by implementing the following simple logic.
The OldVal Event Data Node stores a previous control value. You can use it to compare new data and retrieve the changed index by iterating through arrays with enabled Conditional Terminal. At the end of execution of the For Loop, you will receive array of index indicating which element(s) has their value changed.
This approach can be used on other data types too, such as string array, boolean array, cluster array and more.
