How Can I Assign Differents Ports on DNP3?
Updated Oct 10, 2019
  • NI-Industrial Communications for DNP3
Can I assign a separate port for each DNP3 channel so that timeouts do not block working channels at the same time?
Yes, we can assign a separate port for each DNP3 channel by using a Property node, as you can see in the picture:
