Archived:Which Drivers Are Required for My SCXI Modules?
Updated Dec 23, 2023
  • Chassis for SCXI
I want to know which driver to install so I can work with my SCXI modules. How do I check the compatibilities between the driver versions and the hardware?
The driver needed for the SCXI hardware is NI-DAQmx
To check the compatibility between the driver version and the LabVIEW version, see the Compatibility Table.
To check the compatibility between the driver version and the hardware used, check the readme of the driver. For example, if you are working with NI-DAQmx 17, open the Readme from the download link and search for your device in the SCXI modules listed as supported by the driver.
Note: Support for SCXI was dropped in NI-DAQmx 19.1 and later.
In the Readme file, you can find all the information concerning the compatibilities (OS, driver version, software version and hardware).
