Slow Settling Time on Digital Output Devices
Updated Apr 4, 2019
  • C Series Digital Module
  • NI-9475
  • C Series Digital Output Device
I have a digital output device like the NI 9475.  I have the device hooked up to a high impedance device such as a MOSFET gate and when I go from high to low, it takes a long time to get back to the low state and looks like capacitive decay. How can I fix this?
Digital output devices have a large input impedance and with a high impedance source device, there will be minimal current flow and therefore take a long time to settle.  Consider adding a pull down resistor to the output line to allow a path to ground.
Pull up and and pull down resistors are resistors used to drain charge from communication lines allowing the logic level to settle to their respective state.
