For the First Error message:This error is a generic error that can occur when certain parts of the software install process fail.
For a PXI Linux Real-Time Controller, the most common cause is being unable to contact the online NI Software Repository and therefore being unable to install the software. This could be for a number of reasons:
- The controller is connected to a Host PC via a link-local connection.
- The controller is on a network not connected to the internet.
- The controller is blocked from accessing the feeds by a network firewall.
- The feeds are temporarily unavailable.
To resolve this case:
- Ensure that your controller is connected to the internet and can reach the NI Repository.
- Format the real time target and attempt to install software.
- Try to install the software from another PC that does not have the same network restrictions.
- Try updating NI MAX to the most updated version. This can be done by installing the System Configuration software.
- Verify that the controller's time/date is accurate. An incorrect time/date could result in a certificate mismatch with the download server.
For a CompactRIO Linux Real Time Controller:
- If you are connected to a VPN, disconnect from the VPN and try to install the software again. IT security over the VPN could be blocking the software installation.
For the Second Error message:There are two options to resolve this error message:
- Uninstall and reinstall the driver set being referenced in the error message
- Uninstall and reinstall all NI software
