Will the LabVIEW OPC UA Toolkit work on VxWorks Targets?
Updated Jun 24, 2019
  • CompactRIO Controller
  • LabVIEW OPC UA Toolkit
The LabVIEW OPC UA Toolkit is only compatible with both Windows and NI Linux Real-Time operating systems, so it cannot be installed on a targets running VxWorks RTS.
If you must be able to communicate using OPC UA on a VxWorks cRIO, you can install and use the LabVIEW Real-Time Module 2013-2016 or LabVIEW Datalogging and Supervisory Control (DSC) Module 2013-2016 , both of which include OPC UA functionality that can be installed and run on VxWorks targets..
