Export a Digital Waveform Array Using Export Waveforms to Spreadsheet File VI
Updated Apr 1, 2019
I would like to export a digital waveforms array usingĀ Export Waveforms to Spreadsheet File VI.
When I use an analog waveforms array I'm able to use the VI but if I use a digital waveforms array I get a broken wire.
This VI does not support digital waveform array. If you want to use this VI you can only use digital waveform with multiple signals instead of digital waveform array.
