Cannot Use Multiple Controller VXI System with NI-VXI
Updated Mar 29, 2019
  • Controller for VXI
  • VXI Software
  • NI-VXI
I am using a single PC to control two VXI chassis.  Each VXI chassis has it's own slot 0 controller.  When I try to communicate with modules, I find that I can only communicate with one chassis or the other from my program.  I'm using the NI-VXI API to program the application and GetDevInfo() will only return information from one of the chassis.
The NI-VXI API only supports a single controller for a VXI system.  For a multiple controller system you must use the NI-VISA API to program your application.
If you need to use two chassis and the NI-VXI API, you can use a VXI extender to have a single controller for a two chassis system.
