Error -30000 When Configuring PXIe-4154 in Teststand Using IVI Power Supply Step
Updated Mar 29, 2019
  • PXIe-4154
  • TestStand 2017
  • NI-DCPower 18.0
I am trying to configure NI power supply PXIe-4154 in Teststand using the IVI Power Supply step type. I am validating the settings in the Validate IVI Configuration window. However, whenever I click on Init and followed by Configure, I always get the following error:
The IVI Configure operation failed for logical name 'mySMU'.
Details: Invalid procedure call or argument
(-30000)
The card works fine, as I can still use the Soft front panel or Labview NI-DCPower VI's to control it without issue. How do I control it with the IVI Step in TestStand?
This issue is fixed in the NI-DCPower 18.5 driver version. Please update your driver to this version.
