NI MAX Features Asking for Login
Updated Apr 9, 2019
  • cDAQ-9188
When I try to use NI MAX features (self-test, reset, etc.) or trying to save settings, it keeps asking for login, but does not accept the correct login information. Even after hard resetting, the default username and password combination is not accepted.
It can happen, that the Database File gets corrupted and causes the described behavior. The solution is resetting the NI MAX Database File.
