With a .NET reference to your camera, you are able to access its properties and methods using property nodes and invoke nodes. The camera class uc480.camera has a Memory property that provides a reference to the camera memory. We can use this memory reference to extract the image data.
- Add a Property Node in the block diagram. Wire the uc480.camera .NET reference to the property node and select the property Memory.
- Add an Invoke Node and select the GetActive method of the Memory class.
- Add a second Invoke Node, reference the Memory class. Select the ToBitmap method.
- Wire the s32MemId output from the GetActive Invoke Node to the s32MemId input of the ToBitmap Invoke Node. This will convert the memory data specified by the s32MemId to a bitmap format.
- With the bitmap reference we can invoke the Save method, and stream it to a System.IO.MemoryStream, from which we can extract the image data.
Note: Please refer to the programing interface documentations and resources provided by Thorlabs for more details about the .NET API usage. The link to the documentation is at the Related Links section of this article.
On details on how to create a System.IO.MemoryStream, extract the image data, and convert it to an IMAQ image, follow the instructions in Convert a .NET PictureBox to an IMAQ Image starting from step 3.
