VeriStand 2017 UI Manager Exit Automatically
Updated Aug 31, 2018
  • VeriStand 2017
I am using VeriStand 2017 and can use system definition and workspace without any problem. However, when using UI Manager, UI manager would crash easily especially when opening system definition in UI manager. I have tried more than three different type of laptops, but all have the same issue. The error message is as follows:
VeriStand.UIManager encountered a problem and must exit.
This is a known issue in VeriStand UI Manager 2017 and has been addressed in the f1 patch. Install the NI VeriStand UI Manager 2017 f1 patch to fix this known issue.
