このコンテンツは設定された言語で表示できません。
Using the BNC-2110 for Analog Output
Updated Jul 8, 2026
  • BNC-2110
I am using a BNC-2110 with my Data Acquisition card, and I need to know how to wire the Analog Out terminals for my device. Do they need to be FS (Floating signal) or GS (Grounded signal) when outputting a signal?
Use the BNC-2110 BNC connectors on the front panel to connect AO <0..7> signals to your DAQ device. The number of connectors you use depends on your DAQ device and application. E/M/S Series DAQ devices can only use the AO <0..1> BNCs. AO Series DAQ devices can use the AO <0..1> and the AO <2..7> BNCs. Refer to your DAQ device documentation for information about the use of these signals.
  • For AO Series Devices Only: When using connectors AO <2..7>, you must move the associated FS/GS switch(es) to the FS position. For any other model, leave the FS/GS switch in the default position (GS).
  • When using the BNC-2110 with Connector 1 of NI 6229/6259/6289 devices, the AO BNCs on the BNC-2110 map to the AO channels on the M Series device.
Please review the BNC-2110 Installation Guide for more information regarding the device's ports.
Additionally, check the Field Wiring and Noise Considerations for Analog Signals to learn more about grounding sensors and signals.
