How to Add the NI-CAN Driver to My Installer in LabWindows/CVI
Updated Nov 6, 2018
  • LabWindows/CVI
  • NI-CAN
I need to add my NI-CAN driver to my LabWindows/CVI Installer and cannot find it. How do I add it in the installer?
When you get to the Drivers & Components section of the Edit Installer prompt you need to uncheck  "Only display run-time installers". NI-CAN does not have run-time engines, only the full version, so you need to enable access to all available drivers that you have on your computer.
This also applies to other drivers that do not have run-time engines. You can check this by going to our website and searching for the appropriate driver(s)
