Access 'Signal Input Range' From a DAQmx Task in LabVIEW
Updated Aug 14, 2018
Is there any way to access the Signal Input Range of my NI-DAQmx task in LabVIEW?
It is not possible to access these values programmatically in LabVIEW. However, it is possible to use a DAQmx Channel Property Node's AI.Max and AI.Min properties to achieve the same functionality. These properties will serve to set the appropriate range in the DAQ device's analog-to-digital converter.
