How to Convert from Boolean Array to Digital in LabVIEW Communications 2.0
Updated Aug 14, 2018
  • LabVIEW Communications System Design Suite 2.0
When searching for a GVI block in LabVIEW Communications to convert from Boolean array to digital, no such GVI is found. How can I find or use this block/feature in LabVIEW Communications?
This feature is not natively supported in NI LabVIEW Communications 2.0. However, you can create a LabVIEW Communications GVI which you can use to convert from Boolean array to digital. You can obtain this VI by following the steps below:
  1. Create a new blank VI LabVIEW
  2. Find the desired “Boolean Array to Digital” VI block in LabVIEW and place it on the block diagram (you can press ‘ctrl + space’ to do a quick search for this in LabVIEW)
  3. Save the VI file you just created in a known destination
  4. Launch the "Code Conversion Utility for LabVIEW Communications 2.0" and add the VI file you just created in LabVIEW, and click convert
  5. You should then be able to click “Open Project” and obtain the corresponding GVI file
