Multicolumn Listbox Seems To Be Limited, How Can I Expand It?
Updated Aug 30, 2018
I'm reading in a large excel file, and want to use the Multicolumn Listbox in LabVIEW.
I've tried using the properties of the Listbox, as well as increasing the size using property nodes.
Neither option lets me expand beyond 314x887.
If you can't substitute the Listbox for an Array, you can write in your file, and the Listbox will resize to display all your data, even if it's bigger that 314x887.
