Saving Current Simulation Setting in Multisim for Future Use
Updated Aug 29, 2022
  • Multisim
I would like to save the settings into a file so I can later re-use the same settings in this or another circuit. How do I save these settings?
In the Multisim user interface, once you have configured new custom simulation settings you can save them if you follow these steps:
  1. Select Simulate » Save Simulation Settings...
  2. Browse to any location in your computer and give the file a name.
  3. Click Save.
The file is now saved with a .dat extension. If later on you would like to load or import these settings to this circuit or another circuit, follow these steps:
  1. Select Simulate » Load Simulation Settings...
  2. Locate the file you saved previously.
  3. Click Open.
Your Multisim simulation settings should now be configured to the ones determined by the file you just open.
