Inconsistent Font Size using Report Generation
Updated Dec 31, 2018
I'm creating a report in HTML that I later convert to pdf file format. My main issue is that parts of the report have bigger font sizes than others.
What can I do?
This is fixed by using the Set Report Font VI.
  • Either configure the font size of your report with a single VI or
  • Place this VI before each text entry in your report.
Note: make sure to wire font settings input unless you pretend to use the default font size.
Set Report Font VI sets the font properties of the report, including those in the headers and footers.
