Error -17208 When Loading a VI in TestStand
Updated Aug 9, 2018
  • TestStand
There are some VI's that I call in certain flow control if statements that are only for specific hardware. If these VIs get loaded before execution I get error -17208 File or directory not found. How can I make sure these VIs aren't pre-loaded?
This can be changed in the Step Properties tab for the step that is calling the module. Then go to the Run Options and then change the Load Option to Load Dynamically.
