National Instruments supports any database or data source that has ODBC or OLE DB drivers through the LabVIEW Database Connectivity Toolkit. The following list describes recommendations for which database client software to use:
- Microsoft Access—NI recommends that you use the Microsoft Jet 4.0 or later OLE DB Provider.
- Microsoft SQL Server—NI recommends that you use the Microsoft OLE DB Provider for SQL Server.
- Oracle—You must install Oracle Client software on the machine to which you install the Database Connectivity Toolkit. NI recommends that you use the Oracle Provider for OLE DB 8.1.6.2.0 or later. You can download the Oracle Provider from the Oracle website at www.oracle.com.
For further details about the LabVIEW Database Connectivity Toolkit please refer to the
readme file.
